NodeMCu Interface with DHT11
ajit_nayak87
Member level 5
I am testing NodeMCu Interface with DHT11 unit. I have used arduino uno board where i am getting proper reading for temp & humidity.
I have attached output Serial for reference.
#include "dht.h"
dht DHT;
#define DHT11_PIN 7
void setup(){
  Serial.begin(115200);
void loop()
  int chk = DHT.read11(DHT11_PIN);
  Serial.print("Temperature = ");
  Serial.println(DHT.temperature);
  Serial.print("Humidity = ");
  Serial.println(DHT.humidity);
  delay(1000);
Now I am testing same code using NodeMCu with SimpleDHT11 library. But Here i wont get Reading from DHT sensor. I tried Power 3.3v with seprate regulator with common ground. But result are same
Code without library . I get an timeout error.
// DHT11 and DHT22 sensor reading demo
// by 'jurs' for Arduino Forum
// DHT functions enumerated
enum {DHT11_SAMPLE, DHT22_SAMPLE, DHT_TEMPERATURE, DHT_HUMIDITY, DHT_DATAPTR};
// Begin of user configuration area
#define DHT_SAMPLE DHT11_SAMPLE // must be DHT11_SAMPLE or DHT22_SAMPLE
#define DHT_PIN 2
// End of user configuration area
// DHT error codes enumerated
enum {DHT_OK=0, DHT_ERROR_TIMEOUT=-1, DHT_ERROR_CRC=-2, DHT_ERROR_UNKNOWN=-3};
void setup()
  Serial.println("DHT Temperature and Huminity Measurement");
// DHT sensor pinout from left to right looking at the gridded side
// 1-VCC  2-DATA  3-NC  4-GND
int dhtCall(byte pin, byte function)
// input parameters are the data pin and one of the DHT functions
// return value is DHT error code with function DHT11_SAMPLE or DHT22_SAMPLE
// alsways do sampling with DHT_OK result before calling other functions
// return value is temperature with function DHT_TEMPERATURE
// return value is humidity with function DHT_HUMIDITY
// return value is pointer to byte array containing raw data with function DHT_DATAPTR
  static int temperature=-999;
  static int humidity=-999;
  static byte data[5]; // 5 bytes to receive 40 data bits
  unsigned int loopCnt; // loop counter
  byte sum;  // checksum
  #define DHT_LOOPS 1800
  int triggerTime;
  switch (function)
    case DHT11_SAMPLE: // REQUEST DHT11 SAMPLE
    case DHT22_SAMPLE: // REQUEST DHT22 SAMPLE
      if (function==DHT11_SAMPLE) triggerTime=20000; // 20000µs trigger time for DHT11
      else triggerTime=1000; // 1000µs trigger time for DHT22
      pinMode(pin, OUTPUT);
      digitalWrite(pin, LOW);
      delayMicroseconds(triggerTime);
      pinMode(pin,INPUT_PULLUP);
      loopCnt = DHT_LOOPS;
      while(digitalRead(pin) == HIGH) if (loopCnt-- == 0) return DHT_ERROR_TIMEOUT;
      while(digitalRead(pin) == LOW) if (loopCnt-- == 0) return DHT_ERROR_TIMEOUT;
      for (byte bitNum=0;bitNum<40;bitNum++) // try reading 40 bits
        delayMicroseconds(32);
        boolean dhtBit=digitalRead(pin);
        bitWrite(data[bitNum/8],7-bitNum%8,dhtBit);
      sum = data[0] + data[1] + data[2] + data[3];
      if (data[4] != sum) return DHT_ERROR_CRC;
        humidity=data[0];
        temperature=data[2];
      else
        humidity=data[0]*256+data[1];
        temperature= (data[2] & 0x7F) * 256 + data[3];
        if (data[2] & 0x80) temperature= -temperature;
      return DHT_OK;
    case DHT_TEMPERATURE:
      return temperature;
    case DHT_HUMIDITY:
      return humidity;
    case DHT_DATAPTR:
      return (int)data;
    default:
      return DHT_ERROR_UNKNOWN;
void loop()
  byte* b; // byte pointer for showing raw data
  switch (dhtCall(DHT_PIN, DHT_SAMPLE)) // always request a sample first
    case DHT_OK: // only if DHT_OK is true, get temperature, humidity and possibly raw data
      Serial.print("Humidity: ");
      Serial.print(dhtCall(DHT_PIN, DHT_HUMIDITY));
      Serial.print("   Temp: ");
      Serial.print(dhtCall(DHT_PIN, DHT_TEMPERATURE));
      Serial.print("     raw data:  ");
      b=(byte*)dhtCall(DHT_PIN, DHT_DATAPTR);
      for (int i=0;i<5;i++)
        Serial.print(b[i]);Serial.print('\t');
      Serial.println();
      break;
    case DHT_ERROR_TIMEOUT:
      Serial.println("Timeout Error");
      break;
    case DHT_ERROR_CRC:
      Serial.println("CRC Error");
      break;
    default:
      Serial.println("Unknown Error");
  delay(2000); // minimum time between two DHT samples is two seconds
SimpleDHTlibrary
#include "SimpleDHT.h"
// for DHT11,
//      VCC: 5V or 3V
//      GND: GND
//      DATA: 2
int pinDHT11 = 2;
SimpleDHT11 dht11;
void setup() {
void loop() {
  // start working...
  Serial.println("=================================");
  Serial.println("Sample DHT11...");
  // read without samples.
  byte temperature = 0;
  byte humidity = 0;
  int err = SimpleDHTErrSuccess;
  if ((err = dht11.read(pinDHT11, &temperature, &humidity, NULL)) != SimpleDHTErrSuccess) {
    Serial.print("Read DHT11 failed, err="); Serial.println(err);delay(1000);
    return;
  Serial.print("Sample OK: ");
  Serial.print((int)temperature); Serial.print(" *C, ");
  Serial.print((int)humidity); Serial.println(" H");
  // DHT11 sampling rate is 1HZ.
  delay(1500);
Are you following the guidelines in the DHT11 data sheet, in particular the delay needed before initializing it and the need for a pull-up resistor and decoupling capacitor if the cable is long?
Brian.
Brian.
I am testing same like wise used for arduino uno. It's working well with arduino uno. Only thing i changes is nodemcu v1. 0 used with simpledht11 library. I am getting time out error. Yes length is short. I have powered using external 3.3v with common ground. If I program without library also I get time out error.
You have defined the sensor pinout with the specific value 7:
#define DHT11_PIN 7
However, from the values defined for ESP8266 at the file pins_arduino.h this number is not assigned to any pin:
static const uint8_t D0   = 16;
static const uint8_t D1   = 5;
static const uint8_t D2   = 4;
static const uint8_t D3   = 0;
static const uint8_t D4   = 2;
static const uint8_t D5   = 14;
static const uint8_t D6   = 12;
static const uint8_t D7   = 13;
static const uint8_t D8   = 15;
static const uint8_t D9   = 3;
static const uint8_t D10  = 1;
So, instead of using a numeral parameter, prefer using mnemonics Dn which turns the code more easy to debug, as well as to match with the pin numbering printed on the board:
BTW, for the NodeMCU board, you should be aware that the following pins have already built-in resistors that assure initial state to these pins during start-up, therefore unless you are plenty sure on how to share them with other signals w/o conflicting, select any others but these ones:
// PIN-27 // D3 : GPIO0 ; // PULL-UP
// PIN-26 // D4 : GPIO2 ; // PULL-UP
// PIN-20 // D8 : GPIO15 ; // PULL-DOWN
