Newbie Question (regarding simulation of BUFGCE module)
adilsaleem
I am trying to implement the clock gating technique using the global clock buffers (Virtex 5 FPGA). For a start i made a small test project just to get familiar with the funtionality of the BUFGCE, which is required to be instantiated in the code. I wrote this test module
module bufg_test(clk,ce,op);
input clk,ce;
output op;
BUFGCE BUFGCE_inst (
.O(op), // Clock buffer output
.CE(ce), // Clock enable input
.I(clk) // Clock buffer input
endmodule
and it's test bench
module tb_bufg_test();
reg clk;
reg ce;
wire op;
bufg_test uut(.clk(clk),.ce(ce),.op(op));
initial begin
clk = 0;
ce = 0;
//wait 100 ns for global reset to finish
#100
ce = 1;
#200 ce = 0;
#400;
$stop;
end
always #20 clk = ~clk;
endmodule
Now the problem is that the output of the BUFGCE is not gated clock. It is exactly the copy of the input clock. I am attaching the wave window.
I am simulating it from ModelSim 6.3 (using libraries (which i compiled first) from Xilinx 10.1webpack)
Any ideas what am i doing wrong here?
sajal1975
Full Member level 2
what is ur exact prolem clearify
