zemloh
Newbie level 3
diffrence between the 2n6400 and the 2n6400g
Ok I am a newb in all this circuitry lingo so help me out. My prof. each gave us a cell phone in which he instructed us to be able to call the phone and be able to start a 7-12v motor. ( I know crazy project. ) well I removed the speaker and checked the output voltage with my multimeter and i'm only getting 00.6 mv from the speaker phone leads now my idea is to hook up a thyristor from the leads the spec. thyristor is model# 2N6400G just follow link
ON SEMICONDUCTOR|2N6400G|SCR Thyristor | Newark Canada
heres the pdf link on the specs:
https://www.onsemi.com/pub_link/Collateral/2N6400-D.PDF
Is .6 mv's enough to open the gate to power the 9v battery I have connected on the anode or cathode ( which one I dont know. I have no clue how to hook up a thyristor in the first place.) My question is...is their an easier way to do this? Is a thyristor a good choice? I need the gate to open letting the 9v send constant current to the motor,. Btw I am using a diffrent power supply, the idea is to have the phone ring sending .6mv's to the thyristors gate which will open the gate and let the 9v battery send power through. does this sound about right? If you look at the specs of the thyristor (pdf.) where am I hooking up the particular wires? The positive output from the phones speaker should be connected to the gate, and where do I connect the neg from the speaker output?? and the 9v battery's positive is hooked to the anode and the neg to the cathode, or vice versa??!! I guess what im getting at is how the hell do I hook this thing up the way I need it. Im running out of time on this project and I need major help!
so pllllleeeeasse any suggestions? thoughts? Concerns? The specs on the thyristor is in pdf. form in the link I posted please help tell me what my minimum volts I need to open the gate! Thanks guys
