node 3 has telephone line .
how we can make a network for internet access through the telephone line.
My que is that what we use to connect these node because it is long apart distance . Switch , router . hub etc.
Switch is enough in case of making LAN only and you will not going to access the internet by any way...
Router is needed in case of getting access to the internet as it is an essential stage before getting into the Web, as the router can read up to layer 3 which switch can not.
Is it really needed to use cat6? i prefer cat5e because i hear the cat6 is preferable for Gigabit ethernet. if you only need an transfer data not a streaming application i prefer using cat5e.
