abcqasim
Newbie level 6
I want to make a circuit which can switch between -48V and 0V by applying TTL Signal. So if anybody has circuit or any suitable idea to do that then please must share it
The TTL signal shouldn't too much of an issue. For the 48V relay switch you might want to try: **broken link removed**. Is it for a LAN driver circuit. Do be careful of the current limits. Also, for conversion to TTL i.e. level translation, you can use a buffer for converting logic levels plenty around e.g. CD4504 (very old, try a newer one) be careful of current specs.
