henry15
Newbie level 3
Hi friends,
My project is to interface PIC16F877A with LM35 and when it gets body temperature between 37.5 Celsius to 40.0 Celsius, the led red light and buzzer should turn ON.
If the body temperature is between 36.8 Celsius to 37.5 Celsius, the led green turn on and it will check temperature every 15 minutes once....
Can anyone one help to understanding me the code for PIC....
Below this is my code....
#include <pic.h>
__CONFIG ( 0x3F32 );
#define rs RE0 // Connect pin RS to RE0
#define e RE1 // Connect pin E to RE1
#define lcd_data PORTD // Connect D0-D7 to RD0-RD7 of SB40A accordingly
void delay(unsigned long data);
void send_config(unsigned char data);
void send_char(unsigned char data);
void e_pulse(void);
void lcd_goto(unsigned char data);
void lcd_clr(void);
void send_string(const char *s);
void loop(void);
unsigned char step=0;
unsigned char lcd_count=0;
unsigned char sequence=0;
unsigned char testbit=0x01;
//main function
void main(void)
// LCD main functions
ADCON1=0B00000010; //SET re0-re2 as digital output
TRISE=0B000;
TRISD=0B00000000; //set portD as output
sequence=0;
send_config(0b00001001); //clear display at lcd
send_config(0b00000010); //Lcd Return to home
send_config(0b00000110); //entry mode-cursor increase 1
send_config(0b00001100); //diplay on, cursor off and cursor blink off
send_config(0b00111000); //function
lcd_clr();
lcd_goto(0);
send_string("Patient A:");
lcd_goto(20);
send_string("Patient B:");
delay(100000);
//LED main function
TRISA = 0b00000000; //set PORTA as output
loop();
for( ;data>0;data-=1);
//LED functions
void loop()
while(1) //continuous loop
PORTA=0B11111111;
delay(100000);
PORTA=0B00000000;
delay(100000);
//LCD functions
rs=0; //clear rs into config mode
lcd_data=data;
delay(50);
e_pulse();
rs=1; //set rs into write mode
lcd_data=data;
delay(50);
e_pulse();
void e_pulse(void)
e=1;
delay(50);
e=0;
delay(50);
if(data<16)
send_config(0x80+data);
else
data=data-20;
send_config(0xc0+data);
void lcd_clr(void)
send_config(0x01);
delay(50);
unsigned char i=0;
while (s && *s)send_char (*s++);
#include <pic.h>
void e_pulse(void);
void lcd_clr(void);
void loop(void);
//main function
void main(void)
TRISE=0B000;
sequence=0;
lcd_clr();
lcd_goto(0);
lcd_goto(20);
delay(100000);
//LED main function
loop();
//LED functions
void loop()
PORTA=0B11111111;
delay(100000);
PORTA=0B00000000;
delay(100000);
//LCD functions
lcd_data=data;
delay(50);
e_pulse();
lcd_data=data;
delay(50);
e_pulse();
void e_pulse(void)
e=1;
delay(50);
e=0;
delay(50);
if(data<16)
else
data=data-20;
void lcd_clr(void)
send_config(0x01);
delay(50);
unsigned char i=0;
