Need your help: sensor fusion
mohamedmedhat
Newbie level 3
adxl330
hello everyone, i am working on a balancing robot project, and for it to work properly i need to get the roll and pitch angles correctly
that could be done by means of sensors fusion of gyroscope and accelerometer, either using kalman filtering or external circuit to combine both readings
i am in desperate need to get the kalman filter for that process, the accelerometer i use is the ADXL330 , the gyroscope is the IDG500 and the microcontroller is PIC16f877
please reply to me , and i am an assembler so please even if you can even make it using C language i'd be gratful, comments appreciated
idg500 balancing robot
i use is the ADXL330 , and the microcontroller is PIC16f877
my project is to build system with pic1f877\a and adxl330 and max232
please if u can send me the code how to read from adxl330
nachum.adi@gmail.com
thank you
