Need to trigger 4 relays for a single pulse
anbudanarunm
Newbie level 5
Chennai
Hai, I am new to this forum. I am in a need to design a circuit which need to trigger 4 relays for a single pulse. My trigger pulse will come from the IC 74LS318. Basically it's an 3 to 8 line decoder. can any help me to solve this?
HEllo,
Try to use a flip-flop SR and with transistors on the output to drive the relays.
Regards,
Bruno
could please provide the basic circuit diagram for this if possible
hey if u want to use 3 to 8 decoder then u need 3 inputs , use D-flip flop on the output of each decoder line & a driver to trigger the relay thatz it
I have one more doubt. Shall i use the ULN2803 which is a relay driver at the outputs of D flip flop(74LS138) and connect 4 relays/ULN2803 output directly.
yes u can use ULN2803 (max = 500mA) as a Relay driver. hey don't 4get to connect pin#10 of ULN2803 with +ve supply
another option is u can use a simple cheap transistor(as a switch) + diode as a relay driver
don't 4get to press helped me button
