Need to measure the internal resistance of a battery
Ultor
Newbie level 3
Newbie level 3
how to measure internal resistance of a battery
What's a good method to periodically measure the internal resistance of a battery while the battery is in use.
If that's not possible, how can I measure the battery's internal resistance while it is still connected but not in use?
Any ideas anyone?
fxxjssc
Member level 4
Member level 4
please see TI's patent of BQ20z80 which is newest battery gauge product. I forget the US patent number, but with the internal resistor measured, the accuracy would be better than 99%. good luck
    Ultor
IanP
Advanced Member level 7
West Coast
As the internal resistance of a battery depends on several factors (% of charge, temperature etc, etc) any measurements will be only estimations ..
For the basic method have a look in "output impedance"- batteries at:
https://www.answers.com/topic/output-impedance
Regards,
IanP
    Ultor
electronics_kumar
Advanced Member level 2
Tamilnadu
for a voltage source, internal resistance should be less than load resistance and viceversa for current source..battery is a voltage source....
