I'm new here and I have a rather elementary question. I live in Europe but just bought a rackmount synthesizer from the states...the Roland D-550.
So, I need to convert it to european voltage and have some questions: I've read the service manual and the power supply is universal and has slots for 100V, 117V, 220V and 240V...My country is on 230V, which one should I choose? 220V or 240V?
Moreover, the power supply uses 2 fuses:
1. The main fuse (F1) is a 315mA 250V and should be changed to a 160mA T 250V fuse..I do have a spare 400mA T 250V fuse but I suppose I should not use it?
2. The second fuse (F2) is a 1.25A N1 250V and should be changed to a 1.25A T 250V...do I really need to change this one too or to change the main fuse is enough?
On question one, always follow the manufactures instructions(destructions). The price of a fuse vs the price of your new toy is not worth the risk.
On the second question start out at 240. Putting a lower voltage in than what its designed for is the safer of the two options, but my bet is either will work. Chances are the power supply is a switcher and they tend to handle a wide range of voltages.
Ok, so the synthesizer arrived and I changed the voltage and the fuse!
Now I noticed that the cable that came with it says: 7A, 125V...does this mean that I cannot use it on 220V? It's the 2 prong 110V style but I have a small adapter to 220V 2-prong and tried to connect to mains for a while and was OK...
