Hi friends,
I am using the C8051F340 controller's trigger signal to run the dc motor. This micro controller get the sensor signal to trigger the dc motor. It runs as per the program duration for 16 seconds. After that it should give the another signal to stop the motor. Whenever sensor get closed, Dc motor gets triggered signal from the micro controller. Can i use the single DC source for the circuit(For both micro controller and DC motor)? I use that trigger signal from micro controller to opto coupler , this opto coupler will energize my 12v relay to run the 24V dc motor. This DC motor (24V, 1Amps and 15W) is connected with Motor controller board. It uses the 24 volts from same smps, which is supplied 24V to my circuit board. That trigger signal turn on my motor, but it did not turn off my motor after 16 seconds. Please help me somebody..Herewith i attached my circuit diagram if any mistake, please suggest me to correct.
Thank you..
