Need some VHDL -> System Verilog Conversion
TrickyDicky
Advanced Member level 7
Ok, so I need to become bilingual, but this is just annoying me.
Can someone give me the SV equivolent of this VHDL:
signal ENDSIM : boolean := false;
process
begin
  my_sig1 <= '0';
  my_sig2 <= '1';
  wait until reset = '0';
  while not ENDSIM loop
    --play around with my_sig1 and my_sig2;
    wait until rising_edge(clk);
  end loop;
  wait;
end process;
I dont want to make the process sensitve to clock and reset, I would like it a process with no sensitivity list. If I can get my head around this, then stimulus generation should make more sense to me. This format allows much easier behavioural modelling.
Hi
Here is a quick and dirty untested version:
bit       ENDSIM = 1'b0;
logic    my_sig1 = 1'b0;
logic    my_sig2 = 1'b1;
always
   begin
      while (reset);
      while (!ENDSIM)
         begin
            // playtime
            @(posedge clk);
         end // while (!ENDSIM)
   end // always
Its a bit early for me so there could be some big flat forehead mistakes!
r.b.
I tried this, but all it seems to do is kill Questa:
always
  begin : StimGen
    data        <= 0;
    mu_ch_cnt   <= 0;
    wait (areset == 0) $display("Starting stimulus generation");
    while (!KILLSIM)
    begin
      data      <= data      + 1;
      mu_ch_cnt <= mu_ch_cnt + 1;
      @(posedge clk);
    end
    $display("Stimulus Stopped");
    disable StimGen;
  end
Define "kill"! Where does it die?
It is hard to say, but KILLSIM is never set so it may run forever, and since you are using non-blocking assignments (<=) I am not sure what states data and mu_ch_cnt will take when. "data", for example, will not take the value of 0 until the simulation moved forward in time (i.e. at a clock edge). I am not sure if a wait statement will make that happen.
I would have expected it to work but perhaps someone you has used SV more extensively for verification could chime in.
r.b.
Re: Need some VHDL -&gt; System Verilog Conversion
It appears to get into an infinite loop somewhere, and needs to be killed via the task manager.
Killsim is defined and used here:
bit KILLSIM = 0;
initial
  begin : ClockGen
    clk = 0;
    forever
    begin
      #(CLKPERIOD) clk = !clk;
      //Force a timeout
      if ( $time > (2*TIMEOUT*CLKPERIOD ) )  //x2 for rise and fall
      begin
        $display("Testbench timed out after %d clocks", TIMEOUT);
        KILLSIM = 1;
        disable ClockGen;
      end
    end
  end
the problem may be the fact Im using an always rather than an initial block?
You could change to an initial block and try it. Or use a fork/join block where one fork is the timer and one is the sim, and the timer disables the sim fork (explicitly via a disable or by asserting KILLSIM) when the time period is reached. Then the sim block is neither initial or always, it is a fork.
Sorry for the quick (potentially unhelpful) comments, I am in meetings today...
r.b.
In VHDL:
process
begin
-- some code
wait;
end
translates to Verilog
initial
begin
// some code
end
while (expression);
is an infinite loop if the expression is true. The correct translation is
bit ENDSIM = false;
initial
begin
  my_sig1 <= 0;
  my_sig2 <= 1';
  wait(reset == 0);
  while (! ENDSIM) begin : loop
    //play around with my_sig1 and my_sig2;
    @(posedge clk);
  end
