najamussaqib
Hi everybody,i want to do beam steering through antenna arrays in both azimuth and elevation. please suggest me which antenna array should I use.???
hi
if your frequency range is high enough you can use microstrip antenna.because it is very simple to manufacture and the samples are closely the same which is very helpful in final response and calibration.if the frequency is not high enough you can use dipole antenna
I think that circular array might fit for your need. Its beam can be steered to cover 360 degrees in azimuthal plane.
The beam steering can be performed by adjusting the phase excitation of array elements.
yes you are right bro..but i want to steer it in elevation plane as well..is it possible to do that??
