ADGAN
Full Member level 5
- Joined
- Oct 9, 2013
- Messages
- 295
- Helped
- 4
- Reputation
- 8
- Reaction score
- 4
- Trophy points
- 18
- Activity points
- 1,837
Hi! I need to develop a energy meter for my HND diploma project. I'm hoping to use MCP3901 to measure the energy consumption of the load. I went through the datasheet & the reference design. The reference design has been designed using PIC18F65J90. ( **broken link removed** )
My first problem is whether it is possible to use a different microcontroller than the PIC18F65J90, if so I'm hoping to use a one from PIC18F family like PIC18F45J10 which is able to connect to a breadboard and has a built-in EEPROM. (I'm more familiar with PIC16F887) Does it really necessary to use an external EEPROM. If I use a different microcontroller will it affect the calibration process?
Another problem is that why does this meter needs to be calibrated ?
Finally, can somebody explain me the use and the specification of the line shunt (current & voltage) used in the reference design & where can I purchase it online and also what is name of the black colour component connected to the line shunt which is in the bottom of the meter to connect the wires. :-D
Pls I really need an answer
Thanx in advance
Thanx in advance
