Need Schematic For FECOM(SMILE) CA-2111
SeTRoX
Newbie level 6
OLD GWPTEAM Admin
i have FECOM(SMILE) CA-2111 but now this monitor is not working :( ..i open case but i cant fix it..i very very very need schematic files..i must look some input voltage in schematic.but cant find pdf file..please help me.
FECOM
P/N: CA-2111
110-240V 60/50HZ
82KHZ CRT: 0.28 1.8A
SMILE CA-2111 Specifications
Manufacturer: SMILE
Model: CA-2111
Also Known As: CA 2111
Monitor Type: Multisync/Multiscan
VGA frequency compatible: Yes
VGA sync compatible: Unknown
Max Resolution: 1600 x 1280
H Freq/ V Freq: 30-85 Khz / 50-100 Hz
Sync Type: Unknown
Connector: 5 BNC; HD-15
http://www.monitorworld.com/Monitors/smile/ca2111.html
http://www.epinions.com/S0407470_Sm...ional_Users_Series_CA2111/display_~full_specs
Thanks in advance
SeTRoX
Hi!
What is the failure`? If nothing works at all the power supply could be faulty. Check electrolytic capacitors for capacity and low esr. If the power supply doesn't start up at all check the few small elcaps at primary side, and also the startup circuit. Especially the high-ohm resistors at the primary side are suspicious.
CU
