i have modified it for pic16f876a as shown below but know output
// Simple program to decode commands of RC5 infrared remote controls
// 01/01/2006 by Daniel Porzig
[BASE 32] Game-Programming (OpenGL) and Microcontroller (PIC)
// ATTENTION! All timer-values just fit, if the controller runs with 20 MHz!!!
// When you use another frequency, the values have to be adapted!
#include <16F876A.h>
#include <string.h>
#use delay(clock=20000000)
#fuses NOWDT,HS, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD
#use rs232(baud=9600,parity=N,xmit=PIN_C7,rcv=PIN_C6,bits=8)
int1 get_RC5(void);
#define IR_INPUT PIN_B0 // the infrared receiver has to be connected to an
// interrupt-pin!
#define IR_STATUS (!input(IR_INPUT)) // invert the signal from the infrared receiver
typedef struct
int8 data[2];
int8 state;
} rc5_struct;
rc5_struct rc5;
#int_EXT
EXT_isr()
get_RC5();
int1 get_RC5(void)
int16 tmp,t;
int i;
int1 inp;
set_timer1(0);
while(IR_STATUS==1);
t=get_timer1();
if ((t<400) || (t>800)) return 0; // no RC5 code, abort decoding
for (i=0;i<13;i++)
inp=IR_STATUS;
set_timer1(0);
while (IR_STATUS==inp)
t=get_timer1();
if (t>800) return 0; // no RC5 code, abort decoding
tmp<<=1;
if (inp==0) tmp++;
set_timer1(0);
while (get_timer1()<776); // a simple delay would work here as well
tmp=tmp | 0x3000;
tmp=tmp & 0x37ff; // cut off togglebit
rc5.data[0]=tmp & 0xff; // device address
tmp>>=8;
rc5.data[1]=tmp & 0xff; // command code
rc5.state = 1;
disable_interrupts(INT_EXT);
return 1;
void main()
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
setup_timer_2(T2_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
enable_interrupts(INT_EXT);
enable_interrupts(GLOBAL);
rc5.state = 0;
while(1)
if(rc5.state==1) // did we receive a valid RC5 - command?
// interprete the command here...
printf("Device: %u\n", rc5.data[0]); // display device address
printf("Command: %u\n", rc5.data[1]); // display command code
rc5.state = 0;
please help me to get output
