Need nokia 6111 service manual
billabongcasey
Newbie level 1
schematic 6111 auricular
Can anyone help me find this service manual or at least instructions on how to change fascia and lcd.
many thanks
schematic 6111 auicular
hi,
6111 service manual.
wbr
nokia 6111 manual
does this manual have instructions of how to open the 6111 mobile phone?
no m8,
it is just schematic diagram.
for opening phone ypu need L1-2 service manuals.
wbr
how to open nokia 6111
is there a way of taking off the middle keypad without breaking the phone
open nokia 6111
so where can i found L1-2 manual
6111 disassembly
hi mikejohnston13,
i have finally opened this phone. 1st you have to remove two screws from the pack side of screen part (the phone consists of tho parts screen and keypad) 2nd you need a small flat screwdriver an to puss smoothly two klips at the bottom (opsite side, in the middle there is a little gap) while you are holding the phone close- not extended.
    V
taking apart nokia 6111
hatzitheo said:
hi mikejohnston13,
Hi, I've removed the screws and the cover, however, I'm not sure I understand what you mean by "Opposite side inn the middle there is a little gap" Opposite to what? Furthermore the 2 clips of which you speak are not apparently obvious, could be you possibly be more descriptive?
Andy
nokia 6111 take apart
我想要6111 說明書呀~
opening nokia 6111
I have a nokia 6111 Disassembly video if it is of any use? i also have have the Disassembly videos for a few other nokias
6111 service manual
I ALSO URGENTLY REQUIRE THIS MANUAL.
I HAVE JUST SPILT A CUP OF TEA OVER MY PHONE AND NEED TO FIND OUT HOW TO TAKE IT APART
CAN ANYONE PLZ HELP ME!
Added after 28 minutes:
I HAVE DISCOVERED THAT IF YOU TAKE OUT THE TWO SCREWS FROM BY THE SIM CARD HOLDER YOU CAN TAKE OFF THE FRONT KEY PAD/SCREEN.
YOU ALSO NEED TO PRIZE THE FRONT OFF WHEN THE SCREEN IS IN THE CLOSED POSITION (BE CAREFULL AS IT IS A BIT TRICKY!)
nokia 6111 schematic
dam im trying to replace my screen!!
service manual 6111
search it from answers.com, most probably u will get it.....
nokia 6111 open
thanks for the manual jus replying for points thaank!!! YoouuU!!!
manual de servicio nokia 6111
to open the phone u must remove the silver plastic surround the keypad then u will find 4 screw remove them the remove the above 2 screw u will open the phone
nokia 6111 user manual
it appears the web site is no longer actve
