Need matlab code for sine function
rizwan12
Junior Member level 1
HI everyone.
I want to plot a signal of sine wave with a frequency of 0.1 hz with an amplitude of -50 to 50 and time interval of 0 to 3500.can any anoe help me plz
regards
Rizwan
When you say time interval of 3500, does that mean you have 3500 time steps per cycle? Then your frequency of 0.1 Hz is a cycle every ten seconds, and each time step is .00286 seconds.
Here is how I would write a routine in BASIC programming language.
(2 * Pi is one cycle in radian-based trig calculations as commonly used in computer routines.)
Code Basic4GL - [expand]
8
9
10
11
12
13
FOR div = 0 to 3500
A = 2 * Pi * div / 3500
B = SINE ( A )
amplitude = B * 50
elapsedtime = 10 * div / 3500
PRINT div, elapsedtime, amplitude
NEXT div
Of course you will scale the plot values to fit your screen.
Hiya Rizwan,
Like Brad, I'm not sure what you mean by a "time interval of 0 to 3500"..? If I interpret your requirement as "for a time interval of 3500 [seconds]", then a suitable MATLAB snippet could be:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
tD = 3500;      % [s]  Time duration
f  = 0.1;       % [Hz] Sine frequency
A  = 50;        % [-]  Dimensionless peak amplitude
Fs = 10;        % [Hz] Sampling frequency
t = 0:(1/Fs):(tD-1/Fs);  % Construct a vector of sampling 'instants' over the specified duration
sinOut = A*sin(2*pi*t*f);
% Plot it!
figure;
plot (t, sinOut);
ylim([-A-10 A+10]);
title(['A ' num2str(f) ' Hz sine wave over ' num2str(tD) ' seconds.']);
xlabel('Time [seconds]')
ylabel('Amplitude');
grid on;
The only extra thing I had to specify was a 'sampling frequency' (Fs) - or how often we calculate (and plot) a point over your 3500 second interval. The Nyquist criterion demands that Fs must be at least twice the signal of interest (0.1 Hz), so while anything > 0.2Hz would work, I chose 10 [Hz] to make it all look pretty (and PC memory's cheap ;)
To zoom in on the plot without disturbing your vertical scale (which I've set to something aesthetically pleasing via the ylim([ ]) command), right click in the figure and select 'Horizontal zoom only'.
Cheers :)
