need hlep about the langle coulper's maxim transmit power
bolin
Newbie level 2
Newbie level 2
Could anyone tell me the maxim power the langle coulper can conduct. So I can use it as a power combiner in my PA design. Thank insight!
Re: need hlep about the langle coulper's maxim transmit powe
If you are using stripline like lines then maximum power the langle coulper can conduct will be equal to maximum power handling capability of that transmission line.
I do not know, but I guess that you might have trouble starting in the 10-20 watt range. Langes have very narrow lines, which could vaporize. There are tiny wirebonds that can fuse at 0.5 amps of RF current. You have very tight dimenions that could arc-over due to high E field. If you can not get a good answer, do an analysis of the RF current going thru the wirebonds and the max voltage difference between any tight gap layout points and make an educated guess.
