navienavnav
Member level 1
I wrote the following code the purpose of which is to count the number of 1's in an 8-bit binary number....
It is showing the correct count in ISim, but it is showing it as binary. For example, if the number of 1's are 6, then it is showing 110 after simulation in the ISim. Is this the correct way because ISim only shows values in binary (because of the waveform and being a digital output) or am I doing something wrong?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity count_ones_nav is
port ( inp : in std_logic_vector(7 downto 0);
outp : out integer range 0 to 8);
end count_ones_nav;
architecture Behavioral of count_ones_nav is
begin
process(inp)
variable c : integer range 0 to 8;
begin
c := 0;
for x in 0 to 7 loop
if inp(x)='1' then
c:=c+1;
end if;
end loop;
outp<=c;
end process;
end Behavioral;
