mansi0905
Junior Member level 1
i am tryng to use tanner eda licensed version where the license is provided via dongle.
the problem is whenever i try to open sedit after pulging in the dongle it shows following message. i would like
to mention here that i have already saved the .tlu files in the utility folder.
the message displayed on error occurrence is as following message
Checking hardware lock...
Failed to obtain base license.
This feature was not found on this computer.
Environment variable LSERVRC not found. You must have an
'lservrc' license file and an LSERVRC environment variable set to its path.
The 'lservrc' file must have a valid license string for this feature.
