owenljn
Newbie level 6
First thanks for clicking in my thread
I implemented my design for a 4-bit Fibonacci LFSR, but when I try to compile it, it says warning:No clocks defined in design, it compiles successfully but when I test it on DE2 board, it doesn't work, so here's my verilog code:
module LFSR4bit (KEY, LEDG, HEX0);
input [1:0] KEY;
output [3:0] LEDG;
output [0:6] HEX0;
wire [3:0] Q;
wire D;
assign D = Q[2]^Q[3];
Flip_Flop F0 (KEY[0], D, Q[0]);
Flip_Flop F1 (KEY[0], Q[0], Q[1]);
Flip_Flop F2 (KEY[0], Q[1], Q[2]);
Flip_Flop F3 (KEY[0], Q[2], Q[3]);
assign LEDG = Q;
QtoHEX Q0 (Q, HEX0);
endmodule
module Flip_Flop (Clk, D, Q);
input Clk, D;
output Q;
wire Qm;
Dlatch D0 (~Clk, D, Qm);
Dlatch D1 (Clk, Qm, Q);
endmodule
module Dlatch (Clk, D, Q);
input Clk, D;
output Q;
wire R_g, S_g, Qa, Qb /* synthesis keep */ ;
assign S = D;
assign R = ~D;
assign S_g = S & Clk;
assign R_g = R & Clk;
assign Qa = ~(R_g | Qb);
assign Qb = ~(S_g | Qa);
assign Q = Qa;
endmodule
module QtoHEX (Q, HEX);
input [3:0] Q;
output reg [0:6] HEX;
always begin
case (Q)
0:HEX=7'b0000001;
1:HEX=7'b1001111;
2:HEX=7'b0010010;
3:HEX=7'b0000110;
4:HEX=7'b1001100;
5:HEX=7'b0100100;
6:HEX=7'b0100000;
7:HEX=7'b0001111;
8:HEX=7'b0000000;
9:HEX=7'b0001100;
10:HEX=7'b0001000;
11:HEX=7'b1100000;
12:HEX=7'b0110001;
13:HEX=7'b1000010;
14:HEX=7'b0110000;
15:HEX=7'b0111000;
endcase
end
endmodule
Here's the lab question:
A linear feedback shift register (LFSR) produces a sequence of pseudorandom numbers { at each new clock
cycle a new pseudorandom number is generated using the previous state of the circuit.
The initial value of the LFSR is called the seed; as the LFSR is deterministic, the sequence of values that
the circuit generates will be based on its seed. There are a number of dierent types of LFSRs; one is the 4-bit
Fibonacci LFSR1
Figure 2: A four-bit Fibonacci LFSR. Note that if you use a seed of 0000, the LFSR will never change state! An
animated example of this circuit in action is available at https://en.wikipedia.org/wiki/File:LFSR-F4.GIF
PRELAB TODO: Write Verilog code for a 4-bit Fibonacci LFSR. Use KEY0 for the clock, and display
the current number using a 7-segment display. (Hint: get the LFSR working with LED outputs before switching
it to the 7-segment display!)
input [1:0] KEY;
output [3:0] LEDG;
output [0:6] HEX0;
wire [3:0] Q;
wire D;
assign LEDG = Q;
endmodule
input Clk, D;
output Q;
wire Qm;
endmodule
input Clk, D;
output Q;
assign S = D;
assign R = ~D;
assign Q = Qa;
endmodule
input [3:0] Q;
always begin
case (Q)
0:HEX=7'b0000001;
1:HEX=7'b1001111;
2:HEX=7'b0010010;
3:HEX=7'b0000110;
4:HEX=7'b1001100;
5:HEX=7'b0100100;
6:HEX=7'b0100000;
7:HEX=7'b0001111;
8:HEX=7'b0000000;
9:HEX=7'b0001100;
10:HEX=7'b0001000;
11:HEX=7'b1100000;
12:HEX=7'b0110001;
13:HEX=7'b1000010;
14:HEX=7'b0110000;
15:HEX=7'b0111000;
endcase
end
endmodule
Fibonacci LFSR1
