Need help with interview question
ManUtd_Vik
Newbie level 2
Newbie level 2
San Jose, CA
How to implement i - 8 (8 bit length) ?
I answered that I would use a subtractor (modified adder) to construct carry skip or save or similar adder. He refused to accept it. Please help.
Thanks!
converting 8 to binary we get 1000. this means the lower 3 bits of the answer is going to be the lower 3 bits of i,no matter what. So you can instead use a 5 bit subtractor that does(i>>3) - 1 which is going to be a lot simpler and saves area, power and has higher speed. Whould this be a good answer?
if you mean by i>>3 shift right by three ... should work ... will try and get back to you
Thanks legendkiller
Example: I = 0xAA = b10101010 = 170
Shift 1 place right = 0x55 = b01010101 = 85
Shift 1 place right = 0x2A = b00101010 = 42
Shift 1 place right = 0x15 = b00010101 = 21
Subtract 1 = 0x14 = b00010100 = 20
Clearly subtracting 8 from 170 does not result in 20 so (i >> 3) - 1 does not work. It gives (i/8)-1 not 1-8.
The correct answer is to subtract 8 or add 0xF8, ignoring that a carry will be generated.
Brian.
@betwixt
actually the lower 3 bits of i are directly routed to the lower 3 bits of the answer hence you get 10100 from the 5 bit subtractor and 010 from the input i and concatinating it yields 10100010 which is 162. subtracting 8 is the actual answer but why use a full 8 bit subtractor when the lower 3 bits are going to depend on the lower 3 bits of i?
@ManUtd_Vik
you don't need a dedicated shifter circuit. the upper 5 bits can directly be roued to a 5 bit subtractor with the other input set to 1
Although the lower three bits are the same, the answer is correct ONLY if the original value is >= 8. An 8-bit subtractor will indicate a 'borrow' occurred to show the number has turned negative, a 5 bit subtractor will not do that.
Brian.
