Need Help with I2C!!!
hemnath
Advanced Member level 3
Chennai
I'm reading the 16 bit ADC value and displaying in LCD using MCP3421. When i use inbuilt I2C functions in CCS, everything works good. But I'm trying to use the registers and displaying the value. Below program shows how i configured. But in the display, it shows different value what i expect. Please help
HTML:
#include "18F2520.h"
#include "f2520_regs.h"
#fuses INTRC
#use delay(clock=4000000)
#define RS PIN_A2
#define EN PIN_A1
void lcd_init();
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
/********** I2C functions**********/
void I2C_INIT();
void I2C_IDLE();
void I2C_START();
void I2C_RESTART();
void I2C_STOP();
unsigned char READ_ADC();
unsigned int16 high_data, low_data, final_data, value,byte2;
						Main Function
void main()
lcd_init();
I2C_INIT();
printf(lcd_data,"switzer");
lcd_cmd(0x01);
delay_ms(1000);
while(1)
value = READ_ADC();
lcd_cmd(0x80);
printf(lcd_data,"%lu",value);
delay_ms(200);
						I2C Initialization
void I2C_INIT()
TRIS_C3 = 1;		//	configures SCL and SDA pins as inputs
TRIS_C4 = 1;
SSPCON1	=	0x38;	//	Set I2C master mode
SSPCON2	=	0x00;
SSPADD	=	10;		//	100Khz at 4Mhz clock
CKE	=	0;			//	Disable SMBus specific inputs
SMP	=	1;			//	Slew rate control disabled
void I2C_IDLE()
while((SSPCON2 & 0x1F) | R_W);	//	wait for idle and not writing
void I2C_START()
I2C_IDLE();
SEN	=	1;
void I2C_RESTART()
I2C_IDLE();
RSEN	=	1;
void I2C_STOP()
I2C_IDLE();
PEN	=	1;
unsigned char I2C_WRITE (unsigned char I2C_WRITEDATA)
I2C_IDLE();
SSPBUF	=	I2C_WRITEDATA;
return (!ACKSTAT);	//	returns 1 if transmission is acknowledged
int I2C_READ (unsigned char ACK)
unsigned char I2C_READDATA;
RCEN	=	1;
I2C_IDLE();
I2C_READDATA	=	SSPBUF;
I2C_IDLE();
if(ACK)
ACKDT	=	0;
else
ACKDT	=	1;
ACKEN	=	1;
return (I2C_READDATA);
I2C_START();
I2C_WRITE(0xD0);
I2C_WRITE(0x88);
I2C_RESTART();
I2C_WRITE(0xD1);
high_data = I2C_READ(1);
low_data = I2C_READ(1);
byte2 = I2C_READ(0);
I2C_STOP();
final_data = (high_data * 256) + low_data;
return final_data;
void lcd_init()
lcd_cmd(0x30);      // Configure the LCD in 8-bit mode, 1 line and 5x7 font
lcd_cmd(0x0c);      // display on and cursor off
lcd_cmd(0x01);      // clear display screen
lcd_cmd(0x06);      // increment cursor
lcd_cmd(0x80);      // set cursor to 1st line
void lcd_cmd(unsigned char c)
output_b(c);
output_low(RS);
output_high(EN);
delay_ms(15);
output_low(EN);
void lcd_data(unsigned char z)
output_b(z);
output_high(RS);
output_high(EN);
delay_ms(15);
output_low(EN);
What I'm doing wrong?
