Need help with a radio transmitter 27 MHz - AM
Victor Petrescu
Newbie level 2
Hello I have a request if anyone can help me with some answers about this project. I did a radio transmitter in 27 MHz with modulation AM ... and I have problems in maintaining oscillations and I think it is because quartz oscillator. And a second question do not understand why the current from the entry of the third transistor so I have a little ... and so I suspect that the transistor does not open as a resut i don't have enough gain. I would like if anyone can help me fix the problem. I attached 2 photos with the wiring diagram and simulation result. i used to simulate PSPICE .
Thank you very much!
vfone
Advanced Member level 5
Some Spice simulators have problems to start an oscillation when using a crystal model, or the equivalent circuit of a crystal.
Replace the entire equivalent crystal circuit with a simple shunt LC circuit (1uH and 33pF, and keep C9 in place) and you will get the 27MHz oscillation, just to see how the rest of the circuit works.
Victor Petrescu
Newbie level 2
I've done what you said and i obtained this
My concern is that i have quite a lot of amplification, but i'm thinking is because of the soft
FvM
Super Moderator
Staff member
Bochum, Germany
The "amplification" is most likely provided by the output LC filter without an effective load.
The screenshot schematic is hard to read, I can't recognize the modulation source settings. Similarly the waveform doesn't give much information with the presently selected time scale.
BigBoss
Turkey
You intend to AM but you're using C-Class amplifier for that..It's wrong because C-Class amplifiers need relatively high input driving levels.
You have to use A-Class amplifier to amplify the modulated signal.Simulators can sometimes not provide start-up conditions for oscillators as you can see that your oscilaltion is damped and it is dying down.( I guess the oscillator is heavily loaded by the amplifier).
Thake these points into account..
E-design
I reworked the bias values and relaxed the Q of the crystal equivalent circuit a bit. After that the circuit simulated quite quickly and reached a steady state under 250 uS. I agree with BigBoss that you need some buffer stage to prevent loading on the LC tank circuit.
