kickbeer
Full Member level 3
helo,
in the attachment below, there are two differential amplifier. One is differential amplifier with resistive load and the other one with active load. the differential amplifier with resistive load is the original one which i took from ieee article. the second one(with active load) is the modification i made. i did this because i want to increase the gain. My question is, did i modify the differential amplifier (with resistive load) correctly? i doubt this since i connect the drain of both M18 and M19 directly to the gate of M5 and M6.
