Need help shipping data over USB on a Digilent Nexys 2
complicatedquestionjerk
Newbie level 1
Newbie level 1
Have a Nexys2 board, attached to some hardware ADC which is spitting 16bit wide data in serial at 5MHz. I figured it would be trivial to put such data on a computer using such a powerful ASIC, but weeks of research and a **broken link removed** later, I'm flustered.
Can anyone share wisdom on how to do this properly? Manuals? Docs? Anything!
Quick cut & paste from some notes. Too lazy to sort it out, but might get you started faster then your current state of affairs. :p
The code as is (or as was years ago :p) worked in one go. Since then I cobbled on some extra stuff for faster transfers, but that is also years ago. :p Anyways, you can use the sensicomm hdl for the fpga and then the libusb based c code on the PC. I vaguely recall the sensicomm stuff being VHDL and having done a rewrite in verilog, but I digress. Links etc below:
http://www.sensicomm.com/main/projects/fpga/digilent_nexys_usb.shtml
apt-get install fxload libusb-dev sdcc-nf sdcc-ucsim-nf
http://www.sensicomm.com/main/projects/fpga/ieee_fpga.shtml#nexys_usb
http://home.myfairpoint.net/vzenxj75/downloads/fpga_usb_090227.tgz
http://sourceforge.net/projects/fx2lib/
http://www.triplespark.net/elec/periph/USB-FX2/software/fx2pipe.html
http://www.triplespark.net/elec/periph/USB-FX2/software/fx2pipe-0.7.tar.gz
Hope it's of some use.
