Need Help: PLL for 50 Hz
emreozer
Member level 2
Istanbul - Turkey
50hz pll
Hi everyone
I must design a PLL for 50 Hz. Anybody advise me a circuit?
Thanks
circuit of application with nte864
50 Hz is very slow. Check Razavi's book for the schematics.
    emreozer
pll mit 2206
Yes, I know 50 Hz is very ow frequency, but this is special application.
Could you sedn me Razavi's book link?
Thanks
xr-2206 pll
check the possibility of using a digital PLL as well
    emreozer
pll loop 50hz software
Design of Analog CMOS Integrated Circuits - Behzad Razavi. It has a good chapter on PLLs. I believe the main difference between an analog PLL and a digital PLL will be in the design of the voltage controlled oscillator.
    emreozer
need of pll
The problem I see is that you need reference frq. to be min 10x lover to satisfy all the requirements for PLL loop stability. Remember - Razavi and comp do neglect tons of stuff because the analysis would be way too copmlicated.
So a - get the reference freq
b - design vco running at least 10x higher
c- fight with filter - if it is on chip - sorry no way
    emreozer
pll for 50hz
Hello Teddy, what is the "reference frequency"? Will that be the from the signal going into the PFD, in this case 50 Hz? Also, about the reference frequency being at least 10x lower to satisfy loop stability ... can you give some book or journal references about this? Thanks!
    emreozer
I want to regenerate 50 Hz, so I want to use PLL.
Anybody tell me another signal regeration method?
thanks
Yes it is going to PFD
Make VCo at higher frequency and divide it down to 50 Hz
Use razavi's book or the free - PLL Performance, Simulation, and Design - by Dean Banerjee - it is here somewhere. There you learn what to dd
But I tell you 50Hz - hope this is going to be from discretes....
    emreozer
Did you check CD4046 or equivalent ic ?
    emreozer
you can use pll ic or a flip flop this will not be affected by the low frequency
    emreozer
Thanks for all explanations but the output waveform of PLL must be sinusoidal wave form, not square wave.
anybody know PLL for 50 Hz ( has sinusoidal output)?
Hi again
Can I design a PLL by using NTE864 or XR-2206 (Waveform Generator)?
Anybody has application note about NTE864 or XR-2206 or any waveform generator circut schema?
Anybody did it before?
Thanks
