Need help on Philips PDIUSBD11
weeyndha
Full Member level 1
pic16f pdiusbd11
Hi All,
I need help on PDIUSBD11. It keeps interupt register to be 0x0001. I'm not able to disable the HUB function. How should I do?
visit beyond logic website, they have example code using a pic16f877 interfaced to a PDIUSB11. They also piont out the mistakes in Philips data sheet, including the problem you are talking about.
I am using it myself and trying to write a generic C program to enumerate as a HID device.
Still fail
I have visited www.beyondlogic.org and have tried exactly, but still not working. Any suggestion ?
Still fail
I don't have a problem with beyond logic's code.
This is the init code i'm using for the PDIUSB11, you have to call it after every reset.
//------ init usb
void USB_Init(void)
unsigned char Buffer[2];
/* Disable Hub Function in PDIUSBD11 */
Buffer[0] = 0x00;
D11CmdDataWrite(D11_SET_HUB_ADDRESS, Buffer, 1);
/* Set Address to zero (default) and enable function */
Buffer[0] = 0x80;
D11CmdDataWrite(D11_SET_ADDRESS_ENABLE, Buffer, 1);
/* Enable function generic endpoints */
Buffer[0] = 0x02;
D11CmdDataWrite(D11_SET_ENDPOINT_ENABLE, Buffer, 1);
/* Set Mode - Enable SoftConnect */
Buffer[0] = 0x97; /* Embedded Function, SoftConnect, Clk Run, No LazyClk, Remote Wakeup */
Buffer[1] = 0x02; /* CLKOut = 16MHz */
D11CmdDataWrite(D11_SET_MODE, Buffer, 2);
exactally what problem are you having?
