sindkarhm
Newbie level 1
I am new in FPGA programming. I made simple Embedded Project using XPS 10.1. Netlist is generated successfully but while generating Bitstream I received following error.
ERRORar:73 - Cannot find Input file "system_map.ncd". Please verify that your paths and permissions are properly set
for this file.
ERROR:Xflow - Program par returned error code 21. Aborting flow execution...
make: *** [__xps/system_routed] Error 1
Done!
I made many projects but every time same error received.
Pls go through attached project file.
for this file.
Done!
