Darkbyte
Newbie level 3
Second year EE student here. I am doing a project which involve the
usage of microcontrollers , lcd display and sensors.
Currently i am having problem with the RF transmitter as I never
make one before.
This RF transmitter that I am going to make is like this :
The transmitter must be at logic '0' when it is idle. give out a
pulse of logic '1' (signal) when a button is pressed.
Receiver :
When it receive a signal (pulse) , it will send another signal to a
micro controller.
Right now i only need to send/recieve one signal out using the
transmitter and receiver , but i might need to send two or more
signal out together if i have a change in plan.
So I need help/guide in making this RF transmitter and receiver.
I had read various forums and website .
Based on my understanding ,
Transmitter = Produce [Waveforms(Frequency) AC Electrical Signal]
--> Produce Radio wave.
Receiver = Using Conductor --> Get the Radio Wave--> Electrical
Signals --> Depend on the Signal waveform --> Transform into what
ever you want.
For the mode of transferring signals, I will be using FM.
For the modulation of signals , I know there is something call FSK
, FDM and Manchester Coding.
Now I will come to the portion that I don't know.
Encoding and Decoding.
I had observed from various RF diagrams , I think "many use micro
controller because it help them to 1) Generate Different Waveform ,
2) It will help the receiver to determine what to do if it receive
signal of a particular Hz."
It would help if someone can post a basic diagram of RF circuit if
you have , and from here I will learn more about RF and configure
it to serve my needs.
Thanks all ,
From a noobie:sad:
make one before.
Receiver :
micro controller.
ever you want.
Thanks all ,
From a noobie:sad:
