bajji93
Newbie level 5
- Joined
- Nov 7, 2013
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Thiruvottiyur, India, India
- Activity points
- 52
I'm giving my servo's specs here
current drain - 8 mA (idle)
160 mA (no load work)
stall current - 600 mA
operating voltage - 4.8 to 6 V
I'm using 10 servo motor for my robotic leg, which will be controlled by arduino. I tried using a common 7805 for all the 10 servos. But, later i realized that if all the motor are working, it needs 10*160 mA= 1.6 A of current. But, 7805 can out only 1 A of current. So, i decided to use a dedicated 7805 for each of the servos. So, i'll need 10 7805 for that. I'll be using a 11.1 V 3000mAh Li-Ion battery for this.
My question is will each of my 7805 be able to deliver 500mA at 5V if all the servos are working with some reasonable loads.
:shock::shock:
:shock::shock:
