[SOLVED] Need help for Frequency response plot
moonnightingale
Full Member level 6
I have a multiple choice question
I have used fvtool command but i m not getting similar answer from given option
plz help me anf tell me correct option
I will give you only a tip: x[n] - x[n-1]
That means subtracting the previous input from the current one.
i.e., if you have a DC signal, the output will be null...
If this doesn't help you enough, try finding the zero of the system (z transform).
Z-transforming the system:
y = -0.9*z^-1 + x + x*z^-1
the response will be:
H(z) = y/x = (1-z^-1)/(1+0.9*z^-1)
the frequency spectrum can be calculated setting z = exp(j*w*t):
H(j*w) = (1-exp(-j*w*t)/(1+0.9*exp(-j*w*t))
H(0) = 0
In abscissa of yout graph there is the angular frequency w
The correct answer should be D.
