I have a multiple choice question
I have used fvtool command but i m not getting similar answer from given option
plz help me anf tell me correct option
I will give you only a tip: x[n] - x[n-1]
That means subtracting the previous input from the current one.
i.e., if you have a DC signal, the output will be null...
If this doesn't help you enough, try finding the zero of the system (z transform).
