Need help: AVR 8-bit timer
Don_dody
Full Member level 1
Full Member level 1
Indonesia
Can anybody tell me how to calculate OCR0 & OCR2 in timer0 and timer 2?
I've been searching and just found formula to calculate TCNT and OCR1A.
Help me please.
Why is the calculation of OCR0 any different from OCR1A ?
You also haven't mentioned the mcu model
oh, so you mean calculation of OCR0 is the same as OCR1A?
Actually I just need the formula, but if you want to help:
I use AVR ATmega8535
12Mhz
prescaler 1024.
I need, 0.5 ms and 9 ms time interval.
The calculation is the same for any mcu.
First find the frequency of the timer, in your case 12000000/1024 =11718.75Hz
Then the period to see the time it takes for each tick of the timer 1/11718.75Hz= 85.3us
Nor calculate how many ticks you need for required delay.
For 0.5ms 0.0005/0.0000853 = 5.86 , the closest integer is 6 , the compare match value you should use is the result -1 so 6-1=5 (I assume CTC mode , if not you should wait for 6 ticks to get the delay you want)
