Need Help! 6V Battery Charger Problem....
technorachit
Newbie level 6
Newbie level 6
India
Hi...I am Rachit....
I have a 6V/4.5 Ah Battery and i want to charge it..I have been searching the net since many months but I'm not getting any foolproof circuit which i can use..Can anyone suggest me a charger circuit?
awaiting your replies..
Thanks in advance
Rachit[/b]
technorachit said:
Hi...I am Rachit....I have a 6V/4.5 Ah Battery and i want to charge it..I have been searching the net since many months but I'm not getting any foolproof circuit which i can use..Can anyone suggest me a charger circuit?
awaiting your replies..Thanks in advance..Rachit[/b]
Use a 10 volt transformor, rectify, filter it and then use a LM317 TO220 package with heat sink, set the out put to 7.5 to 8volts. This will be your constant voltage battery charger for 6 volts 4.5ah battery. Cheers.
Thanks for your reply, but i want a circuit with a overcharge protection
If you want overcharge protection and have plenty of
time to charge it, you'd just design for something like
a C/10 rate (450mA) and that's your supply headroom
across a fat resistor (like a 9V wall-wart and maybe a 10ohm
resistor for 300mA-ish).
You want a fast charge that rolls off to a trickle, then you
have to be smarter.
This is an international forum. There are many different chemistries used in rechargeable batteries around the world. Maybe in your country only a lead-acid type is used.
Lead-acid, Ni-Cad, Ni-MH and Lithium.
You should tell us which type of battery you are using so we don't need to guess.
flashtech said:
What kind of battery if it's a Maintenance Free battery?
A Ni-Cad, Ni-MH and Lithium battery are all "maintenance free".
Also is a lead-acid battery.
I think maybe your battery is a lead-acid one.
I have a 6V/4.5 Ah SMF Lead acid battery...
The circuit which i've uploaded is download from https://www.electronicsforu.com/
This is a circuit is of a Low Power Emergency Light.
The LEDs in parallel glow with the help of the Lead-Acid battery...This circuit has an overcharge protection. But no indiaction after Charging is completed...Can u people tell me the changes to be done to get a visual indicataion...
Thanks and Regards.
Rachit..:cry:
