need simulation example for INDUCTIVE COUPLING and a bit explaination on which model to use 4m the libraries ??? how to view the changes in voltage across both the inductors .... thanks
hi
if what u want is the mutual coupling then try using linear transformer
its parameters are the inductance of both coils and the coefficient of coupling k
i havent orcad now to give u an example
the mutual coupling between 2 coils is an additional flux between the 2 coils ,determined from the coefficient of coupling (k)
K=range from 0 to 1
each coil has its own inductance as it still a coil!!!
i made an example for mutual inductance but now i havent orcad so i cant give u a simulation example
u can change the parameters (L1,L2,K) by double clicking on the linear transform
