Need circuit diagram for SIM card backup
nyinyiminn
Newbie level 1
Newbie level 1
Hi , Please inform me , i need to back up my sim card. please help me.I need only circuit diagrams.
Re: Sim card backup
hi
Described by ISO 7816 standard. Used in cellular phones, pay TVs, etc.
Pin Name Description
1 VCC +5 VDC power supply input (optional use by the card)
2 RESET Either used itself (reset signal supplied from the interface device) or in combination with an interal reset control circuit (optional use by the card). If internal reset is implemented, the voltage supply on Vcc is mandatory
3 CLOCK Clocking or timing signal (optional use by the card)
4 GND Ground (reference voltage)
5 Vpp Programing voltage input (optional). This contact may be used to supply the voltage required to program or to erase the internal non-volatile memory.
6 I/O Input or Output for serial data to the integrated circuit inside the card
7,8 N/C not used
The dialogue between the interface device and the the card shall be conducted through the consecutive operations:
* connection and activation of the contacts by the interface device
* reset of the card
* answer to reset by the card
* subsequent information exchange between the card and the interface device
* desactivation of the contacts by the interface device
Interfacing smart card isn"t a simple task. Links in the following "source(s)" section leads to description of signals, timings, etc.
LaTeX Commands Quick-Menu:
