Need advice on relay / switch
rwh138
Hello Gentleman,
I need some suggestions, I am hitting road blocks trying to find the right off-the-shelf relay and/or switch. Hopefully you can help me out with a link or better define the product that I need to look for.
I have a 12 volt DC power supply that connects to two electrodes. I need switch / relay (12 volts 1-1 1/2 amps) with a settable interval timer (seconds or minutes) that will switch polarity back and forth on the electrodes while it is powered.
Any idea on where I can find such product.
I was thinking that the switch should have 6 terminals, 2 for inbound power and 4 for outbound power, 2 wires (+/-) to each electrode that be switched back and forth by a timer.
Thank you for your advice.
Richard
Hi rwh138,
You can build the same with 555 timer in Astable mode and an DPDT Relay. we can help you to do that.
If you wish to buy, kindly refer the link Instron Electronics - T-45 Series Timers subsection FORWARD - PAUSE - REVERSE TIMER T45-FR . (googled)
You may get more by googling "forward reverse timer" or like that
Did you mean diy electronics kit or fixed modules ready to work.
In what country.
Regards KAK
@ kak111,
I would be open to either do it yourself kit or fixed modules. I need to make up a few units so the easier it is, the better, I was hoping to get everything for around $6-10 a unit.
Thank you.
Richard
For under 10$ is only one possibility , do it yourself from discrete components.
What is the control range for interval ( ie. min. .... max. time for 1 cycle) ?
( 50% time +/- and 50% time -/+)
Supply voltage 12Vdc
Output to electrodes 1.5A max
Other things ???
I can suggest you a circuit / schematic
Regards KAK
@ kak111,
The desire time interval would to switch back and forth the 12 volt / 1.5A max DC every 60 seconds. Sounds simple but I haven't been able to find anything.
Thank you for your time.
Richard
Google "interval timer". The Velleman Mk111 is an option if you modify the timing and add a DPDT relay. Commercial plug in modules can cost $100 or more.
KAK,
Thank you for your time and attention.
Richard
