Need abbreviations and acronyms of GSM,CDMA,WCDMA etc.
syed intisar haider
Member level 2
Member level 2
abbriviations
hello all
can anybudy give me all the relevant abbriviations with their ancronyms of GSM,CDMA,WCDMA and computer network like TCP /UDP etc
urgently needed
i will be highly thankfull and gratefull
thanks
abbriviations
this is for cdma
Re: abbriviations
gsm:global system for mobile communications
cdma: code division multiple access
wcdma: white cdma
tcp:transmission control protocol
udp:user datagram protocol
best regards
Re: abbriviations
GSM:Global System for Mobile communications , it is wide used all over the world in the first and secound generation of mobile communication.
CDMA: Code Division Multiple Access , higher data rate than GSM, used in USA, and in the 3rd generation of mobile communication systems.
WCDMA: White Code Division Multiple Access
TCP:Transmission Control Protocol
UDP:User Datagram Protocol
:D
Re: abbriviations
wcdma: white cdma
best regards
Added after 14 minutes:
wcdma: white cdma
best regards
Added after 19 seconds:
wcdma: white cdma
best regards
Re: abbriviations
W CDMA is wide band CDMA .Almost all of u mistook it to be white CDMA. there is nothing called white CDMA.
Re: abbriviations
Hello,
whetever was the abbrevatio nur looking for u can use google type in the search button define : XXX where XXX as an example is GSM or CDMA or whetever u r looking for
wish u best of luck
