Need a avoice or analog delay circuit or chips.
pico
Full Member level 6
Hello,
I need a avoice or analog delay circuit or chips.
Any body can help me please.
Thanks in advance.
flatulent
Advanced Member level 5
Middle Earth
reticon
EG&G Reticon once made charge coupled device analog delay lines.
Fairchild also makes them.
If you want to use a PIC type device, you can ADC, FIFO in memory, and then DAC.
johnseven
Junior Member level 3
California
Audio delay
As elektrodians suggested, there are many ways to do your project.
Key words: bucket brigade, analog delay line, ...
If you need high quality go 16 bit A/D , FIFO, D/A. Complex.
For medium quality use the much simpler analog delay line.
Those are used in guitar pedal effects. Around US$120.
Look into Radio Shack (and Digikey, etc) website for analog delay line chips.
FIFO s used to be very easy to build with SRAM and FIFO controller chips, now discontinued.
I can explain a little more on how to build a FIFO using SRAMS, if you're interested.
j7
MielGibson
Newbie level 5
Try DigiKey. Look for MN3008 bucket brigade devices (BBD)made by Matsushita(Panasonic).
