Need 24 channel 3ph DMX light dimmer schamatic
dcddilan
Newbie level 5
Sri Lanka
Hai,
if some knows about 24 channel 3ph DMX light dimmer. schamatics. using microcontroller please send to me. thnaks in advance
MOD[bassa]: Warning! Do not intrude with a new request which is not related to the thread. Read rules, announcements etc... before posting
I'm made 24ch led driver with dmx512.
I used with ATmega128.
So, I made pwm signal as software with timer.
  • dle-24c01_09b.pdf
3 Ph 24 Ch dimmer is too much if you do not limit the outputs per single channel. Consider 16A triac in each channel passing, roughly 10A (2.3 kW), it is 18.4 kW PER PHASE. You will need 3 microcontrollers, anyway, to make even 3 Ph 3 Ch dimmer
