dipakg
Newbie level 6
Hi All,
I tried to run simple sv queue example with ius82_s014 and I observed weird behavior while calling function using void'().
Following is the complete example:
module class_queue;
class trans;
string myname;
int data;
int d_size;
int state;
function new(string name = "");
myname = name;
endfunction
endclass
trans my_trans;
trans trans_queue[$];
int id_queue[$];
initial begin
start_thread_t;
$display("id_queue.size = %0d",id_queue.size);
$display("trans_queue.size = %0d",trans_queue.size);
#10;
void'(flush_cmd_queues());//reports error ::---> *F,INTERR: INTERNAL ERROR
//flush_cmd_queues(); // reports warning :: ---> *W,FUNTSK : function called as a task without void'().
#100 $finish;
end
function flush_cmd_queues();
$display("clearing all the queues");
id_queue.delete;
trans_queue.delete;
endfunction
task start_thread_t;
for(int idx = 0; idx < 10; idx++) begin
my_trans = new("my_trans");
my_trans.data = idx;
my_trans.d_size = 'hf;
my_trans.state = 'hd;
id_queue.push_back(my_trans.data);
trans_queue.push_back(my_trans);
#10;
end
endtask
endmodule
When I ran the simulation using command "irun class_queue.sv", following error message was reported by tool:
Recompiling... reason: file './class_queue.sv' is newer than expected.
expected: Fri Jul 16 12:00:18 2010
actual: Fri Jul 16 12:01:07 2010
file: class_queue.sv
module worklib.class_queue:sv
errors: 0, warnings: 0
Caching library 'worklib' ....... Done
Elaborating the design hierarchy:
Top level design units:
class_queue
ncelab: *F,INTERR: INTERNAL ERROR
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
TOOL: ncelab 08.20-s014
HOSTNAME: ceiclnx5
OPERATING SYSTEM: Linux 2.6.18-164.11.1.el5 #1 SMP Wed Jan 6 13:26:04 EST 2010 x86_64
MESSAGE: cu_check_single_use() - default
irun: *E,ELBERR: Error during elaboration (status 255), exiting.
Can anybody help me in debugging what could be the issue? I would appreciate it...!!!
Thanks,
Dipak
module class_queue;
class trans;
string myname;
int data;
int d_size;
int state;
myname = name;
endfunction
endclass
trans my_trans;
int id_queue[$];
initial begin
start_thread_t;
#10;
#100 $finish;
end
id_queue.delete;
trans_queue.delete;
endfunction
#10;
end
endtask
endmodule
class_queue
HOSTNAME: ceiclnx5
Thanks,
Dipak
