name puzzling in a SPICE code snippet
ruwan2
Member level 5
Member level 5
I am new to SPICE. I do not understand the last comment part (inside /* and */). Can you get its conclusion:
XRC1 will contain a 100K resistor named R2_XRC1, connected between nets B and XRC1_Z
and
XRC2 will contain a 10P capacitor named C3_XRC1, connected between nets B and A !
I also do not see R2_XRC1 besides in the comment. It is an inferenced name: XRC1 part, R2 connect to its pin?
Thanks,
.SUBCKT RCNET X Y \ RVAL CVAL WN INST NODE VALUE
R1 X Y RVAL
INST Y NODE VALUE
C1 Y 0 CVAL
C2 Z 0 CVAL
M1 X Y Z 0 MOSN W= WN L=2U
.ENDS RCNET
/* subcircuit RCNET has two pins, X and Y, and six parameters, RVAL, CVAL, WN, NODE and VALUE. RVAL, CVAL, WN and VALUE will receive numeric values at call time, but INST will be an instance name, and NODE a node name...
// in circuit.nsx:
XRC1 A B \ 100K 10P 15U R2 Z 100K RCNET
XRC2 B C \ 125K 9.7P 27U C3 X 10P RCNET
/* XRC1 will contain a 100K resistor named R2_XRC1, connected between nets B and XRC1_Z, while XRC2 will contain a 10P capacitor named C3_XRC1, connected between nets B and A !
and
Instead of the above, I think the comment should say:
XRC1 will contain a 100k resistor named R2_XRC1, connected between nets XRC1_Y and XRC1_Z
and
XRC2 will contain a 10p capacitor named C3_XRC2, connected between nets B = XRC2_Y and C = XRC2_X
Reactions: ruwan2
    ruwan2
