bluesy
Junior Member level 1
Hi, there are 3 terminal for the resistor where one is minus , another one is plus at two end of the resistor, however, i need to connect the middle terminal to the ground. what should i add to make the resistor connect to ground? i add poly contact for making connection to ground but it doesn't work.I cant pass the LVS. does anyone can help me?? thanks
