multiplie-accumulator unit using radix 2 modified booth algorithm
gstekboy
Member level 5
Member level 5
parallel multiplier-accumulator unit using radix 2 modified booth algorithm
For my project I choose "parallel multiplier-accumulator unit using radix 2 modified booth algorithm" as my base paper.
I'm planning to program this MAC unit in verilog.
But I have some doubts related to the concepts , I know that some members of edaboard has already coded this in verilog.If you can share me the code it will be helpful.
View attachment 05337888_2.pdf
i hope it will help you
module multiplier_booths #(parameter width = 4, no = 3)(
output reg [(2*width-1):0] product,
output reg done,
input [(width-1):0] multiplicand,
input [(width-1):0] multiplier,
input      load,
input clear,
input clock );
reg [(3*width):0] accumulator;
reg [no-1:0] count;
reg [width+1:0] check ;
always@(posedge clock, posedge clear)
if(clear)
begin
accumulator = 0;
done = 0;
check = {(width+1){1'b0}};
end
else if(load)
begin
check = {1'b0,multiplier,1'b0};
count = {no{1'b0}};
end
else
begin
case(check[1:0])
2'b10 :  accumulator[3*width:width] = accumulator[3*width-1:width] + ~({{width{1'b0}},multiplicand}) + 1'b1;
2'b01 :  accumulator[3*width:width] = accumulator[3*width-1:width] +   {{width{1'b0}},multiplicand};
default: accumulator = accumulator;
endcase
if(count == (width))
begin
done = 1'b1;
product = accumulator[(2*width-1):0];
end
accumulator = {accumulator[3*width],accumulator[3*width:1]};
check = {1'b0,check[width+1:1]};
count = count + 1'b1;
end
endmodule
output reg done,
input      load,
input clear,
input clock );
reg [no-1:0] count;
if(clear)
begin
accumulator = 0;
done = 0;
end
else if(load)
begin
count = {no{1'b0}};
end
else
begin
case(check[1:0])
endcase
begin
done = 1'b1;
end
end
endmodule
sorry it is only a part.
can you PM me the remaining codes.
thanks
well i can but its your part to write the code as you are solving the paper, whatever i have posted with that you can analyze and evaluate entire code, if you have queries i can solve them
but the code you posted is for modified booth.
not related to my project
please run the code in Xilinx and see, whether it is related to you or Not and also 70% it is related to your projects need to change some modification so you can develop the new one, This project has already done by so many M.Tech Students and i am the one who examined them
Sorry , it is not for parallel MAC unit.
it is for MAC unit.
