caledonia
Newbie level 6
Hello everybody,
I'm simulating a circuit in Pspice. I need to optimize 2 different parameters in the same time and alsolink others to them trough a mathematic expression.
The parametric AC simulation permits only to change one parameter or other Elemet values if theres a mathematic expression that links them to this Parameter.
A nested parametric sweep exists only in the DC Analysis.
A Montecarlo simulation takes the mathematic expressions only in the nominal sweep into accout and than takes random values.
Can someone help me realize it in pspice with an AC simulation? do I need some code?
or if it dosn't work, can you suggest Programms that can?
Thank you!
Thank you!
