[SOLVED] Multi source error in VHDL
verylsi
Full Member level 2
Full Member level 2
Hello All,
Please look at the following code -
I am geting these errors :
Line 47: Signal data_valid_demod in unit DeModulator(8) is connected to following multiple drivers:
Line 45: Driver 0: output signal data_valid_demod of instance Flip-Flop
Line 47: Driver 7: output signal data_valid_demod of instance Flip-Flop
HTML:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
entity DeModulator is
    Generic
	       symbolLength : integer := 8
    Port (
           clk_demod              : in  STD_LOGIC;
	  reset_async             : in  STD_LOGIC := '0';
	  reset_sync              : in  std_logic := '0';
	  data_valid_noise_out : in  STD_LOGIC := '1';
          data_mod                : in  STD_LOGIC_VECTOR((2*symbolLength -1) DOWNTO 0) := "1001010111101011";
	  data_valid_demod     : out STD_LOGIC;
          data_demod             : out STD_LOGIC_VECTOR((symbolLength -1) DOWNTO 0)
end DeModulator;
architecture RTL of DeModulator is
   signal data_demodulated     : STD_LOGIC_VECTOR((symbolLength -1) DOWNTO 0) := (others =>'0');
begin
---------------------------- Reverse of mod is performed ----------------------------------
Generate_demod : for i in 0 to symbolLength - 1 Generate
process (clk_demod, reset_async)
begin
   if reset_async = '1' then
      data_valid_demod <= '0';
   elsif rising_edge(clk_demod) then
      if reset_sync = '1' then
      elsif data_valid_noise_out = '1' and data_mod(2*i+1) = '0' then
         data_demodulated(i)   <= '1';
        -- data_valid_demod  <= '1';
      elsif data_valid_noise_out = '1' and data_mod(2*i+1) = '1' then
         data_demodulated(i)   <= '0';
      	--data_valid_demod  <= '1';
      else
         data_demodulated(i)    <= data_demodulated(i);
      end if;
   end if;
end process;
end Generate;
I never faced multi source error when I am not updating an output in 2 or more process ?
Hello All,
<snip>
You're updating the signals inside a generate statement that creates multiple instances of drivers. Can't do that either.
Kevin Jennings
Reactions: verylsi
    verylsi
