tijoseymathew
Member level 4
pic18f4550 programmer
PIC's can be programmed in two way the high voltage programming and low voltage programming...
When you use the low voltage programming as in this case you cannot use the PGM pin in your application it will have to be grounded.
the mode of programming is selected by a config bit and is set to low voltage programming by default...
Check out the datasheet for more info
Added after 1 minutes:
reg. whether this will work or not will depend on the software ... anyways the probability of it doing any harm is very low..
Use a new pic for programming as a PIC programmed using HV cannot be programmed in LV unless config are changed..
