MSP430 WDT Application Problem?
orhanli1
Junior Member level 1
Hello everybody.
I took this program from Davie's book for MSP430-1121STK as well
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
Listing 8.1:  Program wdtest1.c to demonstrate the watchdog timer.
//  wdtest1 .c   -  trival   program   to  demonstrate     watchdog    timer
//  Olimex   1121 STK   board ,  32 KHz  ACLK
//  J  H  Davies ,  2007 -05 -10;   IAR  Kickstart    version   3.42 A
# include   < io430x11x1 .h>                         //  Specific   device
//  Pins   for  LEDs   and  button
# define   LED1      P2OUT_bit . P2OUT_3
# define   LED2      P2OUT_bit . P2OUT_4
# define   B1        P2IN_bit . P2IN_1
//  Watchdog    config :   active ,  ACLK /32768   ->  1s  interval ;   clear   counter
# define   WDTCONFIG      ( WDTCNTCL | WDTSSEL )
//  Include    settings    for  _RST / NMI pin   here  as  well
void   main  ( void )
     WDTCTL   =  WDTPW   |  WDTCONFIG ;              //  Configure    and  clear   watchdog
      P2DIR  =  BIT3  |  BIT4 ;                      //  Set  pins  with   LEDs   to  output
      P2OUT  =  BIT3  |  BIT4 ;                      //  LEDs  off  ( active   low )
      for  (;;)   {                                  //  Loop  forever
           LED2  =  ˜ IFG1_bit . WDTIFG ;            //  LED2  shows   state   of  WDTIFG
           if  (B1  ==  1)  {                        //  Button   up
                LED1  =  1;                          //  LED1  off
           } else   {                                //  Button   down
                WDTCTL   =  WDTPW   |  WDTCONFIG ;   //  Feed / pet /kick / clear  watchdog
                LED1  =  0;                          //  LED1  on
and i changed it for MSP430FG4618 board.It's pin descriptions are different than above.
it is
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
#include <msp430.h>
#define LED4 BIT1
#define LED1 BIT2
#define SW1 BIT0
#define WDTCONFIG (WDTCNTCL|WDTSSEL)
void main (void)
    WDTCTL=WDTPW|WDTCONFIG;
    P5DIR=BIT1;
    P2DIR=BIT2;
    for(;;)
        LED4=~IFG1_bit.WDTIFG;
        if(SW1==1)
            P2OUT=BIT2;
        else
            P2OUT=0x00;
But when i compile i take 3 errors
-expected a field name
-expression must be a modifiable value
-identified "IFG1_bit" is undefined (all of are in line 16 LED2 = ˜ IFG1_bit . WDTIFG ; )
i feel that i have to change LED2 = ˜ IFG1_bit . WDTIFG
but what i must write instead of it
BITx is a number, PxOUT_bit.PxOUT_x is a bitfield structure variable :shock:
But you can avoid bitfields using
PxOUT |= BITx; //1
PxOUT &= ~BITx; //0
yeah i know this but i didn'T change LED4=~IFG1_bit.WDTIFG; for avoiding bitfield structure variable
what the exact line must be??
thanks
